Ground Power Monitoring
Monitor and manage power consumption of the ground station for extended operation.
Ground Power Monitoring provides:
  • Battery Status: Real-time battery level monitoring
  • Power Consumption: Track power usage of components
  • Runtime Estimation: Predict remaining operation time
  • Power Optimization: Identify power-saving opportunities
Hardware Requirements​
Power Monitoring Modules​
  • INA219/INA226: I2C current/voltage sensors
  • Built-in Monitoring: Pi 4 has some built-in monitoring
  • External Meters: Dedicated power monitoring devices
  • Smart Batteries: Batteries with built-in monitoring
Integration Methods​
  • GPIO Connection: Connect sensors to GPIO pins
  • I2C Interface: Use I2C bus for sensor communication
  • USB Monitoring: USB power meters and monitors
  • Serial Interface: Serial-connected power monitors
Sensor Configuration​
INA219 Setup​
Connections:
VCC → 3.3V (Pi Pin 1)
GND → Ground (Pi Pin 6)
SDA → GPIO 2 (Pi Pin 3)
SCL → GPIO 3 (Pi Pin 5)
Software Configuration​
  1. Enable I2C interface on Raspberry Pi
  2. Install power monitoring software
  3. Configure sensor addresses
  4. Calibrate sensors for accuracy
  5. Test monitoring functionality
Monitoring Parameters​
Voltage Monitoring​
  • Input Voltage: Monitor supply voltage stability
  • Voltage Drops: Detect voltage sag under load
  • Voltage Thresholds: Set low voltage warnings
  • Voltage History: Track voltage over time
Current Monitoring​
  • Current Draw: Monitor instantaneous current
  • Average Current: Calculate average consumption
  • Peak Current: Track maximum current events
  • Current Profiles: Analyze consumption patterns
Power Calculations​
  • Instantaneous Power: Real-time power consumption
  • Energy Used: Total energy consumed
  • Efficiency: System efficiency calculations
  • Thermal Impact: Power to heat conversion
Display Integration​
OSD Integration​
  • Battery Icon: Visual battery level indicator
  • Voltage Display: Real-time voltage reading
  • Current Display: Current consumption display
  • Runtime Remaining: Estimated time remaining
Ground Station Display​
  • Power Dashboard: Comprehensive power status
  • Historical Graphs: Power consumption over time
  • Alerts: Visual and audio power alerts
  • Trend Analysis: Power usage trend display
Power Management​
Automatic Power Saving​
  • Component Control: Disable unused components
  • Display Dimming: Reduce display brightness
  • WiFi Management: Disable WiFi when not needed
  • CPU Throttling: Reduce CPU speed to save power
Manual Power Control​
  • Component Switches: Manual component on/off
  • Power Profiles: Selectable power modes
  • Priority Systems: Power allocation priorities
  • Emergency Mode: Minimal power emergency mode
Battery Management​
Battery Types​
  • LiPo Batteries: High energy density
  • Li-Ion Batteries: Stable voltage output
  • Lead Acid: Low cost, high capacity
  • NiMH: Reliable, moderate capacity
Battery Monitoring​
  • Cell Monitoring: Individual cell voltage monitoring
  • Balance Monitoring: Cell balance status
  • Temperature: Battery temperature monitoring
  • Health Assessment: Battery condition evaluation
Alert Systems​
Warning Thresholds​
  • Low Voltage: Configurable low voltage warnings
  • High Current: Overcurrent protection alerts
  • Temperature: Overheating warnings
  • Runtime: Low runtime remaining alerts
Alert Methods​
  • Visual Alerts: On-screen warnings
  • Audio Alerts: Audible warning tones
  • Vibration: Haptic feedback alerts
  • Remote Alerts: Send alerts to mobile devices
Performance Optimization​
Power Efficiency​
  • Component Selection: Choose efficient components
  • Voltage Regulation: Efficient power conversion
  • Load Management: Distribute loads evenly
  • Thermal Management: Prevent overheating
Runtime Extension​
  • Power Budgeting: Allocate power to critical functions
  • Duty Cycling: Cycle non-critical components
  • Voltage Optimization: Optimize operating voltages
  • Load Shedding: Disable features to save power
Data Logging​
Log Parameters​
  • Timestamp: Time-based power data
  • Voltage Levels: Voltage measurements
  • Current Draw: Current consumption data
  • Power Consumption: Calculated power usage
  • Component Status: Individual component power states
Analysis Tools​
  • Power Profiles: Analyze typical power usage
  • Efficiency Analysis: Identify inefficiencies
  • Trend Analysis: Long-term power trends
  • Optimization Recommendations: Power saving suggestions
Integration Examples​
Basic Monitoring Setup​
Hardware:
- INA219 sensor on main power rail
- Temperature sensor for thermal monitoring
- Battery voltage divider
Software:
- Real-time power display in OSD
- Low battery warnings
- Power consumption logging
Advanced Power Management​
Components:
- Multiple INA219 sensors for different rails
- Smart battery with I2C interface
- Controllable power switches
- Temperature monitoring
Features:
- Individual component power control
- Predictive battery management
- Automatic power optimization
- Remote power monitoring
Sensor Issues​
  • No Readings: Check I2C connections and addresses
  • Inaccurate Readings: Calibrate sensors properly
  • Intermittent Data: Check power supply stability
  • I2C Conflicts: Resolve I2C address conflicts
Power Problems​
  • Unexpected Shutdowns: Check voltage thresholds
  • High Power Draw: Identify power-hungry components
  • Poor Runtime: Analyze power consumption patterns
  • Voltage Drops: Check connections and wire gauge
Safety Considerations​
Overcurrent Protection​
  • Fuse Protection: Install appropriate fuses
  • Current Limiting: Implement current limiters
  • Thermal Protection: Monitor component temperatures
  • Emergency Shutdown: Quick power disconnect capability
Battery Safety​
  • Overcharge Protection: Prevent battery overcharging
  • Undervoltage Protection: Prevent battery over-discharge
  • Thermal Monitoring: Monitor battery temperature
  • Physical Protection: Protect batteries from damage
:::warning Battery Safety Always use appropriate battery protection systems. LiPo batteries can be dangerous if mishandled. :::
:::tip Calibration Important Accurate power monitoring requires proper sensor calibration. Take time to calibrate sensors correctly for reliable readings. :::
