USB Tethering
USB Tethering allows sharing the OpenHD video and telemetry connection with external devices.
USB Tethering enables:
  • Smartphone/Tablet Connection: View video on mobile devices
  • Laptop Integration: Connect computers for ground control
  • Multiple Display Support: Extend video to additional screens
  • Internet Sharing: Provide internet access to connected devices
Setup Requirements​
Hardware​
  • USB Cable: USB-A to USB-C/Micro-USB (device dependent)
  • Compatible Device: Smartphone, tablet, or computer with USB tethering support
  • Sufficient Power: Ensure adequate power supply for additional devices
Software​
  • QOpen.HD App: For mobile devices
  • Ground Control Software: For computers (QGroundControl, Mission Planner)
Enable USB Tethering​
  1. Connect device via USB cable
  2. Enable USB tethering in OpenHD settings
  3. Configure network settings on connected device
  4. Launch appropriate software (QOpen.HD app or GCS)
Network Configuration​
Default network settings:
  • IP Range: 192.168.42.x
  • Gateway: 192.168.42.1
  • DHCP: Automatic IP assignment
Mobile Device Setup​
Android Devices​
  1. Connect via USB cable
  2. Enable "USB Tethering" in device settings
  3. Install and launch QOpen.HD app
  4. Video should appear automatically
iOS Devices​
  2. Trust the connected device
  3. Install QOpen.HD app (if available)
  4. Configure network settings manually if needed
Computer Integration​
Windows​
  2. Install any required drivers
  3. Configure network adapter settings
  4. Launch ground control software
  5. Connect to OpenHD IP address
Linux​
  2. Configure USB network interface
  3. Set appropriate IP address in range
macOS​
  2. Configure USB Ethernet adapter
  3. Set network configuration
Common Issues​
  • No Network Connection: Check USB cable and device compatibility
  • IP Conflicts: Ensure unique IP addresses
  • Driver Issues: Install appropriate USB drivers
  • Power Issues: Use powered USB hub if needed
Performance Optimization​
  • USB 3.0: Use USB 3.0 ports for better performance
  • Cable Quality: Use high-quality USB cables
  • Power Management: Disable USB power saving
:::info Bandwidth Sharing USB tethering shares the same video stream as the main display. Multiple connections do not increase bandwidth requirements. :::
:::warning Power Consumption Additional connected devices increase power consumption. Monitor battery levels during extended use. :::
