Bidirectional Telemetry
OpenHD 2.0 supports full bidirectional telemetry communication with flight controllers.
Bidirectional telemetry allows:
  • Downlink: Flight controller data to ground station
  • Uplink: Commands from ground station to flight controller
  • Real-time Parameter Changes: Modify flight controller settings remotely
  • Mission Planning: Upload waypoints and missions
Supported Protocols​
  • MAVLink v1: Legacy support
  • MAVLink v2: Recommended protocol with enhanced features
  • Parameter Management: Read and write flight controller parameters
  • Mission Protocol: Upload and download missions
Other Protocols​
  • MSP: MultiWii Serial Protocol support
  • LTM: Lightweight Telemetry
  • FrSky: FrSky telemetry protocol
Flight Controller Setup​
Configure your flight controller for telemetry output:
  • ArduPilot: Set SERIAL ports for MAVLink
  • Betaflight/INAV: Configure MSP or LTM output
  • PX4: Enable MAVLink on appropriate UART
OpenHD Configuration​
Configure telemetry settings in QOpen.HD:
  • Protocol Selection: Choose appropriate telemetry protocol
  • Baud Rate: Match flight controller settings
  • Port Configuration: Select correct UART port
Wiring​
UART Connection​
Connect flight controller to Raspberry Pi UART:
  • TX (FC) → RX (Pi GPIO 10)
  • RX (FC) → TX (Pi GPIO 8)
  • GND → GND
:::warning Voltage Levels Ensure voltage compatibility between flight controller (typically 3.3V) and Raspberry Pi (3.3V). Some older flight controllers use 5V signaling. :::
Ground Control Station Integration​
QGroundControl​
  • Full parameter management
  • Mission planning
  • Real-time telemetry display
Mission Planner​
  • ArduPilot parameter tuning
  • Advanced mission planning
  • Log analysis
QOpen.HD​
  • Built-in telemetry display
  • Basic parameter access
  • Custom OSD elements
:::info Bandwidth Considerations Bidirectional telemetry uses uplink bandwidth. High-frequency parameter requests may impact RC control responsiveness. :::
