QOpenHD (Recommended)
The recommended ground station software for OpenHD systems.
QOpenHD provides:
  • Complete Control: Full access to all OpenHD features
  • Real-time Telemetry: Live flight data display
  • Video Display: High-quality video streaming
  • Configuration Interface: Easy system configuration
Features​
Video Display​
  • Low Latency: Optimized for minimal display delay
  • High Quality: Support for HD video streams
  • Adaptive Quality: Automatic quality adjustment
  • Recording: Built-in video recording capability
Telemetry Integration​
  • Flight Data: Real-time aircraft telemetry
  • OSD Overlay: On-screen display of flight information
  • Alerts: Visual and audio alerts for critical conditions
  • Data Logging: Flight data recording and analysis
Control Interface​
  • Parameter Control: Adjust OpenHD settings
  • Camera Control: PTZ and exposure control
  • RC Integration: RC control pass-through
  • Emergency Functions: Safety and emergency controls
Supported Platforms​
Desktop Platforms​
  • Windows: Windows 10/11 support
  • macOS: Intel and Apple Silicon Macs
  • Linux: Ubuntu, Debian, and other distributions
  • Raspberry Pi: ARM-based ground stations
Mobile Platforms​
  • Android: Android tablets and phones
  • iOS: iPhone and iPad support
  • Custom Hardware: Embedded ground stations
  • SBC Platforms: Single board computer support
Installation​
Windows Installation​
  1. Download QOpenHD installer from releases
  2. Run installer with administrator privileges
  3. Follow installation wizard
  4. Launch QOpenHD from Start Menu
  5. Configure connection settings
macOS Installation​
  1. Download QOpenHD DMG file
  2. Mount disk image and drag to Applications
  3. Allow app in Security & Privacy settings
  4. Launch QOpenHD from Applications
  5. Grant necessary permissions
Linux Installation​
# Download and install package
wget https://github.com/OpenHD/QOpenHD/releases/latest/download/qopenhd.deb
sudo dpkg -i qopenhd.deb
sudo apt-get install -f
# Launch application
qopenhd
Android Installation​
  1. Download APK from GitHub releases
  2. Enable installation from unknown sources
  3. Install APK file
  4. Grant necessary permissions
  5. Configure WiFi connection to OpenHD
Connection Setup​
  • WiFi Connection: Connect to OpenHD WiFi network
  • Ethernet: Wired connection for ground stations
  • USB: Direct USB connection for configuration
  • Network Settings: Custom IP configuration
Display Settings​
  • Resolution: Configure display resolution
  • Fullscreen: Full-screen video display
  • OSD Elements: Customize on-screen display
  • Color Schemes: Adjust display colors
Control Configuration​
  • RC Channels: Map RC control channels
  • Joystick: Configure joystick controls
  • Keyboard: Set keyboard shortcuts
  • Touch Controls: Mobile touch interface
User Interface​
Main Display​
  • Video Window: Primary video display area
  • Telemetry Panel: Flight data sidebar
  • Control Bar: Quick access controls
  • Status Bar: System status information
Configuration Panels​
  • Video Settings: Camera and encoding parameters
  • Radio Settings: RF link configuration
  • System Settings: General system options
  • Advanced Settings: Expert configuration options
Advanced Features​
Multi-Vehicle Support​
  • Vehicle Selection: Switch between multiple aircraft
  • Simultaneous Monitoring: Monitor multiple vehicles
  • Vehicle Identification: Unique vehicle IDs
  • Fleet Management: Manage aircraft fleet
Recording and Streaming​
  • Local Recording: Record video locally
  • Stream Recording: Record incoming streams
  • Live Streaming: Stream to online platforms
  • Replay: Playback recorded flights
Customization​
  • Plugin System: Extend functionality with plugins
  • Custom OSD: Create custom on-screen displays
  • Themes: Visual theme customization
  • Layouts: Customizable interface layouts
Performance Optimization​
Hardware Requirements​
  • Minimum: 2GB RAM, dual-core processor
  • Recommended: 8GB RAM, quad-core processor
  • Graphics: Hardware video decoding support
  • Network: Gigabit Ethernet for best performance
Optimization Tips​
  • Hardware Acceleration: Enable GPU decoding
  • Network Tuning: Optimize network settings
  • Display Settings: Adjust for performance
  • Background Apps: Close unnecessary applications
Connection Issues​
  • No Video: Check WiFi connection and IP settings
  • Poor Quality: Verify signal strength and bandwidth
  • Intermittent Connection: Check interference sources
  • Authentication: Verify network credentials
Performance Problems​
  • High Latency: Optimize video settings and network
  • Stuttering Video: Check CPU usage and graphics drivers
  • Memory Issues: Monitor RAM usage and close other apps
  • Crashes: Update drivers and check system logs
Configuration Problems​
  • Settings Not Saved: Check file permissions
  • Control Issues: Verify RC channel mapping
  • Display Problems: Update graphics drivers
  • Audio Issues: Check audio device configuration
Use Cases​
FPV Flying​
  • Racing: Low-latency video for racing
  • Freestyle: High-quality video for acrobatics
  • Long Range: Extended range capabilities
  • Competition: Tournament and competition use
Professional Applications​
  • Cinematography: High-quality video production
  • Inspection: Industrial inspection tasks
  • Surveying: Mapping and surveying operations
  • Search and Rescue: Emergency response missions
Educational Use​
  • Flight Training: Learn FPV flying safely
  • STEM Education: Science and technology education
  • Research: Academic research applications
  • Demonstrations: Public demonstrations and shows
:::info System Requirements QOpenHD performance depends on your hardware. Ensure your system meets recommended requirements for best experience. :::
:::tip Getting Started Start with default settings and gradually customize based on your needs. The default configuration works well for most users. :::
