Ethernet Hotspot
Ethernet Hotspot provides wired network access to OpenHD video and telemetry data.
Ethernet Hotspot enables:
  • Wired Connection: Stable network connection via Ethernet
  • Higher Bandwidth: Better performance than WiFi
  • Multiple Device Support: Connect switches/hubs for multiple devices
  • Reliable Connection: Less interference than wireless
Hardware Requirements​
Ethernet Adapter​
  • USB-to-Ethernet Adapter: For Raspberry Pi models without built-in Ethernet
  • Built-in Ethernet: Pi 3B+, Pi 4 have built-in Gigabit Ethernet
  • Powered Hub: For multiple device connections
Cables and Switches​
  • Ethernet Cables: Cat5e or Cat6 recommended
  • Network Switch: For connecting multiple devices
  • Power Considerations: Ensure adequate power for all devices
Network Settings​
  • IP Range: 192.168.2.x
  • Gateway: 192.168.2.1
  • DHCP Server: Automatic IP assignment
  • Subnet Mask: 255.255.255.0
Enable Ethernet Hotspot​
  1. Connect Ethernet adapter/cable
  2. Access OpenHD network settings
  3. Enable "Ethernet Hotspot"
  4. Configure IP range if needed
  5. Save and restart networking
Device Connection​
Direct Connection​
  1. Connect device directly via Ethernet cable
  2. Configure network settings (automatic or manual)
  3. Access OpenHD services at gateway IP
  4. Launch appropriate software
Through Network Switch​
  1. Connect OpenHD and devices to network switch
  2. Ensure all devices in same IP range
  3. Configure device network settings
  4. Access OpenHD services
Ground Control Integration​
Computer Connection​
  1. Connect computer via Ethernet
  2. Launch ground control software
  3. Connect to OpenHD IP address (192.168.2.1)
  4. Configure MAVLink connection if needed
Streaming Devices​
  1. Connect streaming device via Ethernet
  2. Configure video input source
  3. Set input to OpenHD IP stream
  4. Configure resolution and quality settings
Performance Benefits​
Stability​
  • No Wireless Interference: Immune to RF interference
  • Reliable Connection: Stable wired connection
  • Consistent Latency: Predictable network performance
Bandwidth​
  • Higher Throughput: Better than WiFi in many conditions
  • Full Duplex: Simultaneous send/receive capability
  • Multiple Streams: Support for multiple concurrent connections
Connection Issues​
  • Cable Problems: Check Ethernet cable integrity
  • IP Conflicts: Verify IP address configuration
  • Adapter Issues: Test USB-Ethernet adapter functionality
  • Power Problems: Ensure adequate power supply
Performance Issues​
  • Slow Transfer: Check cable category and condition
  • High Latency: Verify network configuration
  • Intermittent Connection: Check all cable connections
Use Cases​
Field Operations​
  • Ground Control Station: Stable connection for GCS
  • Video Recording: Direct connection to recording devices
  • Telemetry Logging: Reliable data logging setup
Development and Testing​
  • Debug Access: Direct access for development
  • Performance Testing: Stable connection for testing
  • Multiple Monitors: Connect multiple display devices
:::info Power Requirements Ethernet adapters and connected devices increase power consumption. Plan power budget accordingly. :::
:::tip Performance Optimization Use Gigabit Ethernet adapters and Cat6 cables for best performance, especially with high-resolution video streams. :::
