WiFi Hotspot
The WiFi Hotspot feature allows wireless connection of mobile devices and computers to the OpenHD ground station.
WiFi Hotspot provides:
  • Wireless Video Access: Stream video to mobile devices
  • Telemetry Sharing: Access flight data wirelessly
  • Multiple Device Support: Connect several devices simultaneously
  • Ground Control Access: Wireless connection for GCS software
Default Configuration​
Network Settings​
  • SSID: Open.HD
  • Password: wifiopenhd
  • IP Range: 192.168.1.x
  • Gateway: 192.168.1.1
  • Channel: Auto-selected
Security​
  • WPA2-PSK: Standard WiFi security
  • Custom Password: Can be changed in settings
Setup and Configuration​
Enable WiFi Hotspot​
  1. Access QOpen.HD settings
  2. Navigate to Network settings
  3. Enable "WiFi Hotspot"
  4. Configure SSID and password
  5. Save and restart system
Advanced Settings​
  • Channel Selection: Manual channel selection
  • Bandwidth: 20MHz or 40MHz channel width
  • Power Level: Adjust transmission power
  • Client Limit: Maximum connected devices
Device Connection​
Mobile Devices​
  1. Search for Open.HD WiFi network
  2. Connect using password wifiopenhd
  3. Launch QOpen.HD app
  4. Video should stream automatically
Computers​
  1. Connect to Open.HD WiFi network
  2. Configure IP address (automatic or manual)
  3. Launch ground control software
  4. Connect to ground station IP (192.168.1.1)
Performance Considerations​
Range Limitations​
  • Indoor Range: 10-30 meters typical
  • Outdoor Range: 50-100 meters depending on obstacles
  • Interference: 2.4GHz band subject to WiFi interference
Bandwidth Sharing​
  • Video Quality: May be reduced with multiple clients
  • Latency: Additional latency introduced for wireless clients
  • Connection Stability: Depends on WiFi signal strength
Connection Issues​
  • Wrong Password: Verify password matches configuration
  • IP Conflicts: Check for IP address conflicts
  • Range Issues: Move closer to ground station
  • Interference: Try different WiFi channels
Performance Issues​
  • Slow Video: Reduce connected device count
  • High Latency: Check WiFi signal strength
  • Dropouts: Minimize interference sources
Security Considerations​
Password Security​
  • Change Default Password: Use strong, unique password
  • Regular Updates: Update password periodically
  • Access Control: Monitor connected devices
Network Isolation​
  • Isolated Network: Hotspot creates separate network
  • No Internet Access: Hotspot does not provide internet
  • Local Communication: Only for OpenHD communication
:::warning Interference WiFi Hotspot operates on 2.4GHz band and may interfere with OpenHD transmission if using the same frequency. Consider using 5.8GHz for OpenHD when using WiFi hotspot. :::
:::info Battery Impact WiFi Hotspot increases power consumption. Monitor battery levels during extended use. :::
