Using Only a USB Camera
This guide covers configuration for OpenHD setups using only USB cameras instead of CSI cameras.
USB-only camera setups offer:
  • Plug and Play: Easy connection without CSI cables
  • Camera Flexibility: Use various USB camera types
  • Multiple Cameras: Connect multiple USB cameras
  • Thermal Cameras: Support for USB thermal imaging
Supported USB Cameras​
Standard USB Cameras​
  • Logitech C920: Popular choice with H.264 encoding
  • Generic UVC Cameras: USB Video Class compatible
  • Action Cameras: Some action cameras with USB output
  • IP Camera Adapters: USB to IP camera interfaces
Specialized Cameras​
  • Thermal Cameras: FLIR, Seek Thermal USB cameras
  • High-resolution Cameras: 4K USB cameras
  • Low-light Cameras: Specialized night vision USB cameras
  • Multi-spectral Cameras: Scientific USB cameras
Camera Detection​
  1. Connect USB camera to air unit
  2. Power on OpenHD system
  3. Camera should be auto-detected
  4. Verify detection in QOpen.HD settings
Camera Settings​
  • Resolution: Select appropriate resolution
  • Frame Rate: Configure FPS for latency/quality balance
  • Encoding: H.264 hardware encoding preferred
  • Bitrate: Adjust for range/quality requirements
Hardware Considerations​
Power Requirements​
  • USB Power: Ensure adequate power supply
  • Power Isolation: May need powered USB hub
  • Voltage Stability: USB cameras sensitive to power fluctuations
  • Current Capacity: Check camera power consumption
Mounting and Protection​
  • Secure Mounting: USB connectors can be fragile
  • Cable Management: Secure USB cables properly
  • Environmental Protection: Weatherproof connections if needed
  • Vibration Isolation: Protect from flight vibrations
Performance Characteristics​
Latency​
  • Higher Latency: USB cameras typically have higher latency than CSI
  • Encoding Delays: Software encoding increases latency
  • USB Overhead: USB protocol adds processing time
  • Optimization: Choose cameras with hardware H.264 encoding
Quality​
  • Variable Quality: Depends on camera and encoding
  • Compression: USB bandwidth limits may require compression
  • Format Support: Not all cameras support optimal formats
  • Auto-adjustment: Some cameras have auto-exposure/focus
Setup Process​
Air Unit Configuration​
  2. Configure camera settings in OpenHD
  3. Set appropriate resolution and bitrate
  4. Test video transmission
  5. Optimize settings for your application
Ground Station Setup​
  1. Ensure ground station can receive video
  2. Configure display settings
  3. Test video quality and latency
  4. Adjust settings as needed
Common Issues​
  • Camera Not Detected: Check USB connection and compatibility
  • Poor Video Quality: Adjust resolution and bitrate settings
  • High Latency: Use cameras with hardware encoding
  • Power Issues: Ensure adequate power supply
USB-Specific Problems​
  • Connection Stability: Secure USB connections properly
  • Bandwidth Limitations: Monitor USB bandwidth usage
  • Driver Issues: Ensure proper camera drivers
  • Heat Issues: Monitor camera temperature
Multi-Camera Setup​
Multiple USB Cameras​
  • Dual Camera: Connect two USB cameras for different views
  • Camera Switching: Switch between cameras during flight
  • Picture-in-Picture: Display multiple camera feeds
  • Recording: Record from multiple cameras simultaneously
  1. Connect multiple USB cameras
  2. Configure each camera separately
  3. Set switching controls
  4. Test all camera feeds
  5. Optimize bandwidth allocation
Use Cases​
Thermal Imaging​
  • Search and Rescue: Thermal imaging for SAR operations
  • Industrial Inspection: Equipment monitoring
  • Wildlife Observation: Non-intrusive wildlife study
  • Agricultural Monitoring: Crop health assessment
High-Resolution Video​
  • Cinematic Recording: High-quality video recording
  • Surveying: Detailed aerial surveying
  • Real Estate: Property photography/videography
  • Documentation: Scientific documentation
:::warning Power Consumption USB cameras typically consume more power than CSI cameras. Plan battery capacity accordingly. :::
:::info Compatibility Not all USB cameras are compatible with OpenHD. Test compatibility before final installation. :::
